unexpected token `IKSEMEL,iksemel,'
  • zaiocrit
    • May 2016
    • 15
    Hi
    I'm trying to install Zabbix 3.0.3 in Ubuntu, but I get the following error when launching the ./configure
    error:
    unexpected token `IKSEMEL, iksemel, '
    ./configure: line 9001: syntax error near unexpected token `IKSEMEL,iksemel,'
    ./configure: line 9001: `               PKG_CHECK_MODULES(IKSEMEL,iksemel,'
    and as a consequence, obviously :
    ... # make install
    make: *** No rule to make target 'install'.  Stop.
    this is the code in "config"
    8999  if test "x$_libiksemel_with" != x"no"; then
    9000        if test "$_libiksemel_with" = "yes"; then
    9001		PKG_CHECK_MODULES(IKSEMEL,iksemel,
    9002
    9003			 JABBER_INCDIR="$IKSEMEL_CPPFLAGS"
    9004			 JABBER_LIBDIR="$IKSEMEL_LDFLAGS"
    9005			 JABBER_LIBS="-liksemel"
    9006			,
    9007			 found_iksemel="no"
    9008			 found_jabber="no"
    9009			)
    9010        else
    Can you help me ?
    Andrea
  • DmitryL
    • May 2016
    • 278
    Hello zaiocrit!
    Please check if you have pkgconfig package installed.
    • zaiocrit
      • May 2016
      • 15
      hello Dmitryb !
      Originally posted by Dmitryb
      Hello zaiocrit!
      yes :
      pkg-config 0.29.1-0ubuntu1 amd64
      what "token" can refer? can there be an error in the config file?
      • DmitryL
        • May 2016
        • 278
        Can you tell full ./configure string that you are using?
        Config.log also could help.
        • zaiocrit
          • May 2016
          • 15
          configl.log :
          config.log.zip
          • DmitryL
            • May 2016
            • 278
            Made a test on Ubuntu-15.10 with zabbix-3.0.3 source
            groupadd zabbix
            useradd -g zabbix zabbix
            ./configure --enable-agent
            Works fine....
            pkg-config 0.28
            gcc 5.2.1-22
            Did you tried install agent from packages?
            • zaiocrit
              • May 2016
              • 15
              I installed ubuntu 14 and I have not encountered the same error. I can now configure ZABBIX !
              But I'd like to understand why the 16 does not go
              Thanks !
              • glebs.ivanovskis
                • Jul 2015
                • 237
                If you are building from svn repository you need to re-run ./bootstrap.sh before you re-run ./configure after you installed pkg-config.
